ta girdle
Re: ta girdle
I use a couple bottles of Mobile1 90W gear oil with bottle of GM limited slip additive (ONLY use the GM additive by the way). Also, unless you like it messy later on, put a little sealer on the threads of the pre-load studs on the T/A cover. The will weep fluid out it you don't...
Dave C.
Dave C.
Re: ta girdle
Mine leaks at the drain plug so I'd recommend something to seal that better.
I think synthetic lube is not recommended for our Auburn type differentials so I run regular Valvoline gear lube and GM additive.
carguyshu
Jan 22, 2017 11:19 AM
96SilverRam
Nov 20, 2016 11:19 AM
