T-56 flywheel counterweight question
Old Nov 20, 2003 | 10:21 PM
Red95T/A's Avatar
I just bought a spec aluminum flywheel and I need to have it balanced the same as the stock flywheel and I was just wondering if all flywheels counterweights were the same? Or are they balanced to that specific motor?
Lonnie
Old Nov 21, 2003 | 12:03 AM
J's 82's Avatar
they have a standard "weight" on them.. to be safe I would take your old and new flywheel to a speed shop and have them balanced to match..
Old Nov 21, 2003 | 04:30 AM
rskrause's Avatar
Moderator
There is a standard weight for externally balanced small blocks. If you have a stock rotating assy, it should be fine. OTOH, if you have a non-standard assy. you should do as J suggested and have the new piece balanced to the old one. Provided the old setup was correctly balanced, of course.
Rich Krause
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Ringmaster72
Feb 25, 2015 03:15 PM
Newgmman
Feb 25, 2015 02:53 PM
tonyss1
Aug 5, 2002 08:09 PM
