symptoms of a loose MAP?
Old May 29, 2003 | 02:53 PM
dynomight's Avatar
I am just wondering on some general symptoms that would occur if the MAP sensor was mounted, but not completely tightened down. Thanks...
Old May 29, 2003 | 03:10 PM
If you are really talking about the MAP, it would probably cause sluggish performance and poor gas mileage if it were leaking vacuum.
Old May 29, 2003 | 03:26 PM
dynomight's Avatar
Yes, i am really talking about the MAP. And in particular, would i get anything like this? Car feels as if governed at 2800 rpm. Very bad sputter any gear at around 2800. Parked for testing. Plugs and O2 sensor on the passenger side look normal. Driver side plugs and O2 are black, and reek of fuel, although they are not soaked. The car is modified, like in the sig. Just happened to notice that the thing wasnt tightened down, and i think that it is possible that once the s'charger kicks in, this thing may be lifting to lose vac. Its just an issue i wanna eliminate or check further. Thanks for your time and suggestions...
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
SEOJustin
Sep 24, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
FredM
Aug 14, 2015 01:49 PM
