symptoms of a loose MAP?
Yes, i am really talking about the MAP. And in particular, would i get anything like this? Car feels as if governed at 2800 rpm. Very bad sputter any gear at around 2800. Parked for testing. Plugs and O2 sensor on the passenger side look normal. Driver side plugs and O2 are black, and reek of fuel, although they are not soaked. The car is modified, like in the sig. Just happened to notice that the thing wasnt tightened down, and i think that it is possible that once the s'charger kicks in, this thing may be lifting to lose vac. Its just an issue i wanna eliminate or check further. Thanks for your time and suggestions...
tdigger9899
Sep 7, 2015 10:56 AM
