swapping crank while in the car, possibly with a 383
Old Dec 29, 2003 | 09:58 PM
viperkiller's Avatar
1 is it possible to change the crank in the car, i spun a bearing crank it toast.
2 will the longer stroke fit in the stock block without any machine work??
any knowlege on this will be appreciated
Old Dec 29, 2003 | 10:02 PM
Green G0blin's Avatar
sorry i cant help, but i private messed you from my post, hope you can repsond asap.
Old Dec 29, 2003 | 10:11 PM
engineermike's Avatar
Doubtfull that you can do that.
You usually have to clearance the block so the rod bolts don't hit the oil pan rail.
Mike
Old Dec 29, 2003 | 10:14 PM
jonaddis84's Avatar
dont forget that with a longer stroke you need lower compression height pistons or else the piston is going through the head! Also you would save a lot of time by just taking the motor out, try removing the oil pan while in the car and that will give you an idea of how hard it would be to change out a crank, which i doubt is possible anyway.
Old Dec 29, 2003 | 10:19 PM
97Z-M6's Avatar
the oil pan wasnt that hard to get out of his car. but i see you can do it if you dont have any clearance issues. but i just sont know if we could get it back in with out damaging the crank.
once you get the motor up the oil pan will come right out. oh and the y pipe.
Old Dec 29, 2003 | 10:28 PM
goblin check your mail
i already have the pan off, wasnt to bad. looks like the crank could manuver out. i just had to unbolt the mounts and jack up the engine.
i was concerned about the clearance issues with the block
i just put this motor in last winter, it sucks pulling it out again.
thanks, if anyone else has a magic potion that keeps the engine in the car id like to see it.
also, would it be worth it to stroke a stock bored engine, not a big fan or bored motors.
Old Dec 29, 2003 | 10:33 PM
jonaddis84's Avatar
Bore doesnt mean anything compared to stroke. You would see very very few hp from a .10 or .20 or .30 bore compared to the gains you would see with a stroke increase, only problem is if it needs a bore, go as small as possible though so you can go bigger in future.
On the other hand, stroke increase on otherwise stock engine would mean almost nothing, without better heads or cam you wont see much hp, decent increase in torque though, not much to be worth it though
Old Dec 29, 2003 | 10:52 PM
i have the xe 230 236 in it now. heads need more work. ran out of money last year and needed the car so didnt do the full job on the heads. spent everything i the lower end.
as far as the cylinders you can still see the cross hash from the factory hone, didnt see any grooves or scares. and the car didnt smoke. so i didnt plan to bore.
thanks for you input.
Old Dec 29, 2003 | 11:20 PM
NOMAD's Avatar
Re: swapping crank while in the car, possibly with a 383
One and only reason to pull it there. If you toasted the crank after spinnig a bearing, you'll need to disassemble the engine and get it tanked to remove any bearing residue thats in the oil passages. You will need to get the mains line bored and checked. You will also need a new oil pump along with all new bearings.
Anything less and your gonna be pulling it right back out. Not to mention how unsanitary it would be to drop out and install a crank while the engine is in the car. Save yourself the headache.
Not to mention how your gonna put a stroker crank in an engine without stroker rods nor pistons. You can't just change the crank, your looking at an entire rebuild.
-Shannon
Old Dec 29, 2003 | 11:32 PM
SloLt1Z's Avatar
No you can not just change the crank. You need to have the block clearanced for the stroker crank, you need need connecting rods to do a stroker, not to mention all of the bearings and stuff. And if the crank is shot you NEED to pull the motor and have it rebuilt. The crank needs to be balanced.....blah blah blah.
nballisru
Dec 14, 2014 05:01 PM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
1LEThumper
Jul 14, 2003 12:45 PM
