Swap
Old Jun 23, 2003 | 07:57 AM
nick_ouellette's Avatar
Swap
I am new to this forum and want to know how hard it would be to do a complete swap from V6 to Lt1 and also why i am at How hard would it be to thow an MTX in there...I not to familair with the camaro engine set up but know some...Thanks for any help
-Nick-
Old Jun 23, 2003 | 08:40 AM
joeSS97's Avatar
Well,I have never done it,but it can be done.My opinion is to save yourself a big headache and buy a Z28.Or if you are set on swapping it,go for an LS1.More work,more gains.
Old Jun 23, 2003 | 08:54 AM
It's been done, so I'm sure someone will offer you advice. But you need to remember, there are major differences that need to be addressed:
-different radiator (LT1 is "reverse" cooled)
-different front suspension K-member, motor mounts
-different front springs
-if its a "manual trans" you need the complete drive train including clutch, hydraulics and T56
-different driveshaft (2-piece V6 vs. 1-piece V8, ditch the center support bearing on the torque arm.
-your V6 probably needs a new rear axle, because it lacks disc brakes and a limited slip differential
-new exhaust system
-new instrument cluster
-complete engine with harness and PCM
Starts to sound like a "trade-in" would be a lot more cost effective.
Old Jun 23, 2003 | 09:02 AM
Thanks for the advise Im researching for my Bro because he doesnt know squat about engines and whats involved but that makes alot more since. Maybe Ill just to a new motor swap(V6). Save me some trouble of doing all that crap. I figured the motor mounts were different and such but didnt relize all this was involved damn...Crazyness...
-new exhaust system
Anyways thanks I will just look in to getting an RS engine. May be cheaper than buying a new one.....And one more questions...How hard is it to do an ATX to MTX swap in the V6...I have done the V6 Probe is it generally the same? thanks again
-Nick-
Old Jun 23, 2003 | 10:06 AM
TTT
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
