SVO Injectors? Stock Replacement?
Old Apr 14, 2004 | 12:45 PM
TobyZ28's Avatar
I have a 95Z and want to replace the injectors on it. I hear ford SVO's can be used, but from what i've read they seem to run at a lower PSI.
I think my stock injectors are 24# ones, someone correct this if im wrong. Can I just get 24# SVO ones and swap them in without any problems? Or do I need to get a different rated # one to replace my stock 24# ones?
Also, I have a computer and cable for the car, is there any software out there for free that will allow me to program in a new injector size? I use freescan at the moment.
Old Apr 14, 2004 | 12:51 PM
Derrick Redd's Avatar
You can just swap them out, they work fine. I ran my car with the stock injector constant using the 24# SVO's for about a year. The car will run a hair rich, but nothing drastic. You can go in and tweak the injector constant for optimal results.
Old Apr 14, 2004 | 12:52 PM
TobyZ28's Avatar
Thanks for the info Derrick! Thats good news, any ideas on how i can get in and tweak the injector sizes?
Old Apr 14, 2004 | 01:05 PM
You can use LT1 edit or get someone to program it for you. I had my dyno-tuning done at Thunder Racing. I have since upgraded to 30# SVO's, but I never had a problem running the 24# SVO's with the stock injector constant.
Old Apr 14, 2004 | 10:13 PM
Lt1tko5o's Avatar
As stated above, the 24 lb SVO's will run, but run rich. The fords run 39 psi fuel pressure, since are cars run 42-43 psi, they will flow more fuel than stockers. I use tunnercat to change the injector constants. Here is a link for the correct #'s.
http://carprogrammer.com/Z28/PCM/Injector/injectors.htm
Brian
GigaMp3z
Feb 20, 2003 02:57 PM
mjcent922
Jul 27, 2002 12:42 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
