Surge
Old Jan 2, 2010 | 04:17 PM
  #16
Skullified's Avatar
check one plug and it was white so its running real lean. Could this be because of the fact the my air intake elbow has a rip in it so too much air and not enough fuel?
Old Jan 2, 2010 | 04:41 PM
  #17
Depends how bad the inlet elbow is torn. The PCM can use the long term fuel corrections to compensate for up to 25% extra fuel.
You have to look at the plugs on both banks of the engine - the PCM controls the A/F independantly to each bank.
Old Jan 3, 2010 | 01:08 PM
  #18
Skullified's Avatar
the intake is torn really bad it has chunks actually missing. My symptoms have gotten worse as the intake has ripped more. First being a small rip now chunks missing. If i take the plug from the other side and its lean is that good or bad?
Old Jan 3, 2010 | 06:04 PM
  #19
Quit screwing around and FIX the intake elbow. You are screwing thing up royally by letting all that air bypass the MAF sensor. When you have a KNOWN problem, you fix that before attempting to solve the unknowns.
Old Jan 3, 2010 | 06:08 PM
  #20
Skullified's Avatar
lol easy for you to say dang things are expensive and hard to find for cheap. Since I'm just a broke college student I'm trying to find one for cheap before i give up and spend 70 or 80 bucks.
Old Jan 3, 2010 | 06:19 PM
  #21
2QUIK6's Avatar
How about some duct tape until you find one..better than leaving a gapping hole there...if its running that bad, you may end up with fouled O2 sensors and plugs...that will run more than $50-$70 to replace them then.
Old Jan 3, 2010 | 06:37 PM
  #22
Did you check the parts for sale forum?
If you can't take the time/money to fix it, park the car until you can.
truecontr3
Oct 11, 2015 09:30 AM
Noenav
Apr 30, 2015 01:06 PM
edman
Mar 13, 2015 09:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
scott95ta
Mar 21, 2003 06:57 PM
