summits lt4 hot cam kit?????
Originally posted by pappasmerf18
so who sells the best kit then and if u can give a link that would be great.
CeeBee, I like that package! As a matter of fact I honestly think I will go with that instead! The pushrods don't come with hotcam kit and neither do the gaskets, well at least the pushrods don't I'm not to sure about the gaskets. I also would rather have the Comp Cams roller rockers instead of GMPP's. That sounds really good to me and their cam is bigger than the LT4 cam. I think you made up my mind for me
All I would have to pay for is some Comp R lifters and I might have enough for a computer tune.
How can I get a hold of them and do you recommend someone that I should talk to?
All I would have to pay for is some Comp R lifters and I might have enough for a computer tune.How can I get a hold of them and do you recommend someone that I should talk to?
Computer tune > Comp R lifters
There isn't really a link for the package deal, just go to the group buy section on the site and its there, not sure if the deal is still going on though.
Either way, just give them a call and I am sure that they can hook you up with something
Jason Cromer sells the hot cam kit for 489. I bought it from him and got great service. http://samtaylor.com/html/parts.html
Z95m6, then what do you recommend? Would it be better to just to just keep the stock lifters or should I least should I use some sort of replacement lifters? I just assumed that replacing the lifters would be a must regardless if I get the Comp cam or the LT4 Hotcam and if I was going to get them might as well get something worthwhile.
How bad will the car run without the tune? Will there be driveability issues?
The car will not reach its full potential without a tune. YOU NEED to get it tuned.
Replacing lifters also depends on what RPM's you plan on spinning the engine to. If you are going to consistently spin it over 6000 rpm, I would change the lifters. Stay below that, and the stock ones should be o.k. Just check the bottom of the lifter when you remove them. If it is perfectly flat and not at an angle from wear on the cam, then you should be fine reusing them if you plan to stay below 6000 rpm
Just my opinion.
Dan
Just my opinion.
Dan
Smokn '94 Z
Jul 23, 2002 09:24 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
