suggestions on plug wires?
Old May 25, 2004 | 02:36 PM
97zSC's Avatar
well my opticrap is slowly getting worse and worse, so i figure i might as well do the wires at the same time, since i didnt do em when the plugs were done. just wondering what wires i should get, was thinking about msd or taylor
Old May 25, 2004 | 02:43 PM
Red96Lt1's Avatar
I've heard that the 8mm Taylors are better than 8.5mm MSD. I have Taylors. That's what most people run here.
Old May 25, 2004 | 02:53 PM
Kevin97ss's Avatar
I like MSD wires but the taylor's fit in the factory seperators better. With that said the only problem I had with MSD was routing them around the alt./ps. bracket. Had to make a custom seperator.
Old May 25, 2004 | 04:03 PM
brians96Z's Avatar
I use Moroso Blue Max Spiral Core 8mm wires, and they're great!
Old May 25, 2004 | 04:10 PM
joeSS97's Avatar
Taylors
Old May 25, 2004 | 04:11 PM
Type_O_Negative_1320's Avatar
I've been using Accel Extreme 9000 wires with no problems so far. I wrapped them with Spectre Firebraid to keep temps down since they do come a bit close to the headers. Also, they don't fit in the factory separator under the alternator bracket, so I just popped it out and zip tied them to keep them away from the belt.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
