Header Install
Old May 25, 2004 | 03:59 PM
xcycz28x's Avatar
Header Install
What is the best and easyest way to install Hooker LT's in a 1997 Z 28 I want me and my dad to do it at our house we have all the tools needed but just would like to know what parts to remove and what parts to leave alone.....thank you for all your help
charlie
Old May 25, 2004 | 04:09 PM
PoorMan's Avatar
You need to get the car WAY off the ground. I have a pic in my sig showing my install. 6 ton jack stands for more height. The distance from the ground to the bottom of the front door was about 30" for me. Don't even try until you get it up this high. I spend most of the day jacking alittle, trying, jacking alittle, etc. For the front, I had 6 tons extended all the way and had those on top of 6" blocks(railroad ties) and ramps in the rear. If you get the car up then it's really easy. Both go in from the bottom. Remove the steering knuckle, oil filter, and starter so you aren't fighting it.
Old May 25, 2004 | 04:13 PM
xcycz28x's Avatar
well we can take it to my dad shop and use the car stall thats not a problem I was just wondering about the engine parts to be removed....thanks for the input!
charlie!
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
