Stuttering / Missing
Old Aug 26, 2008 | 07:43 PM
GMH94Z28's Avatar
I just got done installing a cc503 cam last weekend and it idles and revs fine but today i drove it longer than 30 minutes and i noticed that it almost feels like i have a litle mis or stutter under light acceleration. If i get on it it does fine. I didnt know if this was normal with a cam or not. Any ideas? Thanks
Old Aug 27, 2008 | 12:10 AM
DelSoto's Avatar
That does not sound normal. You have what some guys on here would call a smallish cam. I am running a GM847 which is a rather large cam and it doesn't miss or stutter. Double check all of your wiring. After a cam install, it is not unusual to overlook something simple.
Old Aug 27, 2008 | 11:13 AM
SnakeSkinner28's Avatar
could be a vacuum leak somewhere as well, check everything that could cause a leak, also look for burned wires just in case.
Old Aug 27, 2008 | 12:52 PM
GMH94Z28's Avatar
I did notice that my intake is leaking oil on the back side of it. Safe to assume if oil is getting out air is getting in?
Old Aug 27, 2008 | 07:32 PM
But the air entering the typical oil leak at the rear of the intake manifold would only be "getting in" to the crankcase. Its not a vacuum leak an the true sense.
Old Aug 29, 2008 | 09:53 PM
GMH94Z28's Avatar
What is the best way to find a vacuum leak?
Old Aug 29, 2008 | 11:07 PM
GMH94Z28's Avatar
Reading more on my stumble it almost sounds like cam surge. Is this normal for a cc503?
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
