stupid door locks
Old Feb 26, 2004 | 12:48 AM
PredatorZ28's Avatar
stupid door locks
my door locks stopped working after i blew the acc fuse. I replaced the fuse and still no dice, so i replaced the driverside switch and now the passager side one unlocks but doesnt lock, it didnt nothing before. The driverside still does nothing with the new switch, should i try replacing the passagerside switch? btw the locks worked perfect before the fuse blew.. is there another fuse somewhere? thanks also i have a viper alarm that might be messing with it?
Old Feb 26, 2004 | 04:38 AM
Tair's Avatar
check EVERY fuse in the fuse block on the left side of the dash.
Old Feb 28, 2004 | 06:27 PM
i did that i even tested them, anything else?
Old Feb 29, 2004 | 04:15 PM
ChickenScreamer94's Avatar
Did you make sure that the new switch has the harness on it good and secure? I know that the system wont work if one switch is disconnected. If not then maybe the fuse that was in there was the wrong amperage (ie too high) and didnt protect the circuit(s). I really have no knowledge of the power locks or wiring. GEt a manual or go to the dealer
88IROC_Z
Jul 22, 2015 11:38 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
dolfan324
Jul 17, 2015 10:34 PM
gelbza
Jul 12, 2015 08:10 AM
CARiD
Jul 7, 2015 08:19 AM
