Stumbling, Spittering, Backfiring...(Delteq)
Old Dec 6, 2004 | 10:19 PM
  #16
99BlackTA's Avatar
Re: Stumbling, Spittering, Backfiring...(Delteq)
Give Pete a call at Delteq and tell him of your problems if you haven't already. He is trying to figure something out with my car as we speak.
Old Dec 7, 2004 | 12:13 PM
  #17
ejfagala's Avatar
UGGGGG,
I think I can tell you what the problem is and niether of us want to here it. I had a crazy miss at 4K and it ended up being the opti. I swaped the opti last week end and it solved the 4K miss problem but now my car runs like crap for about 1-2 min in the morning. With the old opti I did not have the problems in the morning, it has only started after I did the sawp. I think I am going to just live with the problem for now because that job sucks but I am going to give Pete a call.
Old Dec 7, 2004 | 01:59 PM
  #18
aintno6's Avatar
Did you change the plugs and wires before your did the install? If so I would look them over. Because it sounds like your car is only doing this in open loop mode. Where it runs on the stock a/f tables. Maybe they arent cutting it. And once the pcm goes closed loop, it fixes the issue.
This is a guess. But honestly is your best shot, and will cost you no money to check. Looking at your scanmaster, do you notice anything out of the ordinary? Are you 100% that you inspected all the parts you moved/tampered with durring the install?
Mike
Old Dec 7, 2004 | 03:21 PM
  #19
99BlackTA's Avatar
I have inspected everything. The opti was perfectly fine before the install. I als changed the plugs but went with the exact same type.
Old Dec 7, 2004 | 10:25 PM
  #20
99BlackTA's Avatar
I changed out PCM's tonight and that had no affect on the way it ran either so it can't be in the tune of mine. Now on to more tests....
Old Dec 16, 2004 | 07:40 PM
  #21
99BlackTA's Avatar
I am still fighting this problem. I might put the original ignition system back on it soon and get rid of the Delteq.
Old Feb 11, 2005 | 11:18 PM
  #22
blue's Avatar
Did you figure it out?
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
