Stroker guys. What weight oil do you use?
Just wondering what the consensus is for you 383/396's. What a safe all around weight? It's been so long I can't remember what the shop recommended me. 3rd rebuild. I figure 10/30 dino oil unit I hit 3K then switch to mobil syn 10/30.
Thanks.
Thanks.
Originally posted by rskrause
10W-30 is probably fine for most situations.
Rich Krause
Rich Krause
Patman.....the oil researcher did a lot of study time on it. Do a search.
It's true, Mobil 1 makes one of the thinner 10w30s out there, Redline or Amsoil 10w30 is much thicker at 100C.
Depending on your clearances, you may want to step up to a 10w40 though, something in the 13-14cst at 100C range (a thin to medium 40wt) Many stroker motors also use looser clearances, hence my suggestion for something slightly thicker.
Rich Krause
Rich Krause
Thx,
Claude
I know my cars not a stroker but its got some mods , I run 20w-50 year round in all my cars and none have ever needed a rebuild although I can get away with that down here in nc cuz it almost never gets below freezing here . I like the oil pressure to be nice and high
Re: Stroker guys. What weight oil do you use?
Thanks.
Thanks.
There's no substitute for pure raw US powerplants from stoplight to stoplight.
just an FYI, i know most of your engine builders told you what to use and i would follow them but for the rest of us, 5w-30 is the best all around method, 80% of engine wear occures during the first minute of driving. I doo reccomend Syth tho, I use M1 5w-30 in the winter and seeing that it is one of the thinner 10w-30s out there i use it in the summer. It seems to be working just fine, well that an i aviod FRAM filters like the black death, only use Purolator or AcDelco. But that is just me.
I was trying to keep it simple. 10W-30 is fine for most motors/uses. Mine is setup loose with a high oil pressure to cushion the bearings from a big nitrous shot. I use 20W-50 but the car is not used in cold weather and I never put a load on it until the oil is warm.
But 10W-30 is a good all around choice.
Rich Krause
Rich Krause
