to stroke or not to stroke
Old Jul 1, 2005 | 11:28 AM
  #31
1racerdude's Avatar
Re: to stroke or not to stroke
Originally Posted by hallbilly
OK, final delimma... if i go with a 355, i could put a few more bucks with the money i would save... and get a good set of heads that Lloyd could hog out. have a killer set of heads, and probably the same power... or a tid bit more. Am I wrong?
Ya can make the same power but it will be a hell of a lot more radical and much less streetable.
Ya would have to turn it higher and the torque wouldn't be as much.
Old Jul 1, 2005 | 12:09 PM
  #32
hallbilly's Avatar
so, with larger heads... could i run a smaller cam and be more streetable and have around same power?
Just trying to cover all of my options before I start spending my dough...
Old Jul 1, 2005 | 12:31 PM
  #33
1racerdude's Avatar
Yes big heads,smaller cam for the same HP level.
Old Jul 1, 2005 | 01:48 PM
  #34
hallbilly's Avatar
What would be be some good head choices? ive heard afr 210's/ 220's and the tfs 195's... is there any other options?
Old Jul 1, 2005 | 03:07 PM
  #35
1racerdude's Avatar
Dart if ya want to convert them(335CFM) AFR if ya don't want to convert 227's ( around 315CFM) 12 week wait and offset train if ya want it.Can be used with stud mount RR's.
210/220 are not a bad choice if max ported( about 280CFM).
Depends on what ya want for HP and what the budget can stand.
Old Jul 2, 2005 | 11:12 AM
  #36
marshall93z's Avatar
Max ported???
Old Jul 4, 2005 | 04:34 PM
  #37
1racerdude's Avatar
Originally Posted by marshall93z
Max ported???
Yea,ALL ya can get port wise and valve wise..Isn't that what max means.
Old Jul 5, 2005 | 08:55 PM
  #38
hallbilly's Avatar
ok... after hours upon hours of crunching $$ numbers, and weighing all of my options vs. results... i've decided to go with the 383 on LE3 heads and a "emissions" cam. I will NOT run boost or nitrous therefor I do not need the strongest rods/pistons... Rods... H beams are nice but i doubt they are necessary for 450rwhp max (i know i wont make that much... but close ) What about some eagle I beams 6.0". Pistons, don't want to go too cheap here ~500-600 bucks... but what are some good tough pistons for 6.0" rods; -3cc to -5cc dish pistons... crankshaft? eagle cast crank? and what are the best bearings!?
if you guys know of any other parts that are better let me know!
Thanks!
Old Jul 10, 2005 | 10:24 AM
  #39
LOL!!
I know what max is, but I didn't know that max ported AFR's would only flow 280 CFM!
Old Jul 10, 2005 | 10:38 AM
  #40
1racerdude's Avatar
LOL!!
My porter says AFR has a "happy flow bench" and on his bench they won't flow their adv numbers. He says he can get right at 300CFM from a set with plenty of hand work after he runs his CNC program on them.
Old Jul 10, 2005 | 10:46 AM
  #41
There seems to be ALOT of "happy flow benches" around these days!
Old Jul 10, 2005 | 11:28 AM
  #42
1racerdude's Avatar
O yeeeeaaaaa-------- big number's sells heads.
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
smoknta
Aug 27, 2015 05:07 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
realistyc
Jul 28, 2015 07:32 PM
