to stroke or not to stroke
Old Jun 26, 2005 | 10:27 PM
  #16
1racerdude's Avatar
Re: to stroke or not to stroke
Originally Posted by hallbilly
Yup, summit has them... Ive been wanting a 6AL for a while now... 230 for that and i think 121 for the timing controler. Now, time to find the right parts to up the DCR
Goforit.
Old Jun 26, 2005 | 10:45 PM
  #17
SStrokerAce's Avatar
Originally Posted by marshall93z
LR, the timing retard you mention sounds like a good idea. Never thought of that before!
Bret, do you see a problem with doing it that way?
No it's a good idea, i've used these boxes on the dyno to find the correct timing for a motor quicker... it's a good idea.
Bret
Old Jun 27, 2005 | 06:27 PM
  #18
marshall93z's Avatar
Bret
Ok, cool.
Old Jun 27, 2005 | 06:33 PM
  #19
What about elevation? Say it is Summer in Vegas and he has it turned down with the box. Now he wants to go to a place that the elevation is a good 1000 feet lower, or more. Is there enough adjustment with the box, or will he be in trouble? Or is elevation even that big of a deal with DCR?
Old Jun 27, 2005 | 06:56 PM
  #20
DA is a factor with DCR yes... the denser the air the lower the DCR should be, so yeah elevation plays into that. The Box has like 9degs if I remember right, if you can't take enough out with that you are doing something wrong.
Bret
Old Jun 27, 2005 | 07:08 PM
  #21
1racerdude's Avatar
I'm at sea level and it works down here but it was MAX tuned here.
I would imagine ya could dream up a situation that it wouldn't work but ya would have to do a LOT of thinking.
Well I reckon I will just have to think up another "trick" to get an edge on these boys.Reckon I could put ours on fuel and go for it.With the **** ya could do either fuel or pump gas.
Old Jun 27, 2005 | 07:55 PM
  #22
hallbilly's Avatar
Didn't even think about elevation that much... There is Mt. Charleston with lots of twisties that I am anxious to eat up when I put ole betsy back together. So that would be like a 7k ft increase in elevation. Very fun driving!
Emailed Lloyd to see if he would hook me up with the IVC close of a few cam options... I'm glad I posted this in here, you guys are very helpfull! THANKS! Now hopefully in time I will end up with a combination that works very well together
Old Jun 27, 2005 | 09:54 PM
  #23
I can help you with the DCR but he probably is not going to give out the IVC of the cams.....
If there is something you want to shoot for just tell him and we can set the DCR to that level for you as long as you give me all the mesurements for the Compression Ratio.
Bret
Old Jun 28, 2005 | 07:48 PM
  #24
Will he not got the IVC even if he buys the stuff from Lloyd?
Old Jun 28, 2005 | 08:35 PM
  #25
cat1055man's Avatar
I hear the crank can handle ~500, but I doubt it would last for any time if you drive wot all the time... So 8.3 DCR would be a better number to shoot for or should I go with the 8.7 for the little bit of umph.
I understand static compression ratio, but can someone explain how dynamic compression ratio is calculated or determined...please educate me.
Thanks, Craig
Old Jun 28, 2005 | 08:40 PM
  #26
1racerdude's Avatar
Thanks, Craig
Go on line and find ya a calculator.Enter the figures and get the DCR.
DCR is what the engine actually SEES when running and it's got to do with the IVC point. The higher the static the more the DCR in the same engine combo.
Old Jun 29, 2005 | 04:57 PM
  #27
cat1055man's Avatar
I gonna do just dat to figger this out...thanks for the tip and all the info.
Old Jun 29, 2005 | 06:41 PM
  #28
hallbilly's Avatar
well, im going to shoot for about 8.6-8.9... dont know what dish pistons i will need yet... right now they have me lined up for -5cc but not a big deal to change. I figure i will ship my heads to lloyd and let yall fix me up. that way when i get my goodies back I will know more about the cam profile.
Old Jun 29, 2005 | 07:23 PM
  #29
Not a problem man...
When you get the cam you could figure IVC with a degree wheel without much problem. I try to shoot for 8.3 DCR on Lloyds packages to make them fool proof and have lots of TQ and HP. Going farther sometimes happens with some customers, but for the most part they are designed for this range just so they are safe.
Bret
Old Jul 1, 2005 | 10:42 AM
  #30
hallbilly's Avatar
OK, final delimma... if i go with a 355, i could put a few more bucks with the money i would save... and get a good set of heads that Lloyd could hog out. have a killer set of heads, and probably the same power... or a tid bit more. Am I wrong?
