Striped lugnut bolts ?
Old Apr 11, 2003 | 10:08 PM
Ben383's Avatar
Was wondering how I would go about changing these out ? It's the back passenger side that need thems . Any help is thankful
Ben
Old Apr 11, 2003 | 10:30 PM
RENE95Z's Avatar
Are you saying the threads are stripped, or the hex is stripped. If it is the hex, pull out the trusty vice grips, a couple beers, and a few cigarettes if you smoke and go to town.
Old Apr 11, 2003 | 10:45 PM
Ben383's Avatar
It's the lugnut bolt threads that are striped ?
Old Apr 11, 2003 | 11:24 PM
Spin the axle until you find enough room behind the lug that will allow it to come out. Pound out the lug bolt with a hammer. Use only enough force to get it out-don't go wild with a big hammer.
Slip the new lug bolt in from the back. On the front, use some washers as spacers and tighten a lug nut on it (use the flat side of the lug nut toward the washer-backwards as to how you normally put it on) to pull the bolt fully into the axle hole.
Old Apr 11, 2003 | 11:31 PM
Ben383's Avatar
Shoebox - Thanks for the information . I'll attempt to do same tomorrow .
Old Apr 11, 2003 | 11:34 PM
Of course, there really is a c-clamp looking tool you are supposed to use to press the stud out. Just be careful with the hammer as not to warp the axle flange.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
dale3in98
Feb 14, 2015 12:18 PM
