Strange Idle Surge???
Old Jan 24, 2005 | 08:31 PM
  #16
camzaro28's Avatar
Re: Strange Idle Surge???
about 2 months after i did my TB bypass i startedhaving the same problems as you. sometimes it took like 20 minutes for the car to start! anywaymy prob was when i did the TB bypass i pinched the MAP sensor wires between the alternator bracket and the coolant return line(i think that is what it was!) adn after a while it ate through it, and started to ground itself out when wires started to show!
just and idea though. and if that is not it, you could check other areas that might have gotten pinched or what not! good luck
Old Jan 25, 2005 | 10:10 AM
  #17
SS#771's Avatar
please anyone i need some more ideas on this
Old Jan 25, 2005 | 11:12 AM
  #18
944v8inDFW's Avatar
if your intake boot is torn, won't even ask how that happened, you can get all kinds of strange running problems. get it replaced first then if a problem still happens post the problem. Intake leaks after the maf can do all kind of strange things including a miss like effect, high or low idle, hard starts and on and on. Your problem may be a very simple one and you are not fixing the problem that is in your face.
Old Jan 25, 2005 | 04:39 PM
  #19
SS#771's Avatar
ttt
Old Jan 25, 2005 | 08:51 PM
  #20
944v8inDFW's Avatar
Originally Posted by SS#771
i checked it again and im pretty sure this is being caused my intake elbow...it had been torn for awhile and i havent gotten around to buying another one....it is an extremely loud rushing air sound.
not trying to be a jerk but if you think you know what the problem why not fix it instead of bumping your thread? bumping your thread dont fix the problem fact is it may just pi** off the moderators
You could always run a poll!
question 1: Should I fix the apparent problem?
question 2: Should I keep bumping my post?
question 3: Should I call Miss Cleo for answers?
question 4: Do Nothing?
hope that helps good luck! \
Quickss96
Jan 29, 2016 05:56 PM
FredM
Aug 14, 2015 01:49 PM
Rittmeister
Aug 12, 2015 03:50 AM
KYWes
Aug 10, 2015 07:03 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
