Stock Rotating Assembly Cabalities
Old Jul 25, 2009 | 06:24 PM
rustykey's Avatar
I am about to start a budget build 355 and alot of my direction depends on how much power the stock rotating assembly can handle. So I guess my question is how far can I push it without hurting it. If it can handle a motor build of say 550hp at the flywheel then I will use the stock bottom end with forged pistons. If not I am just going to build a 383. Any help is appreciated. Sorry if this is a question you guys see often. Oh yeah, motor only no spray.
Old Jul 25, 2009 | 09:01 PM
slomarao's Avatar
the crank is good till 7-800hp. Many have taken it that farther. Would i, no.
the rods are okay but by the time you put ARP hardware into them your 80-90 bucks away from some cheap forged I beams.
Pistons I would go with something cheaper, anything forged. you want to keep even strength in your bottom end.
to make your desired hp your going to have to spin a 355 close to 7k. 4 bolt main.
What are you planning on for the topend?? AI/LE??
Old Jul 25, 2009 | 09:51 PM
rustykey's Avatar
The top end will be most likely be AI or LE setup. What do you guys think of the SCAT steel crank with forged rods and pistons if I do the 383 build.
Old Jul 26, 2009 | 07:20 PM
1982z28with18s's Avatar
Stock crank is plenty strong, I pushed it to just shy of 900 crank HP.
Old Jul 27, 2009 | 02:40 PM
slomarao's Avatar
Scat is the only crank i ever heard of breaking. Not to saying anything bad about them, but its the only one I remember breaking.
Are you set on a 383??
Old Jul 27, 2009 | 03:27 PM
rustykey's Avatar
No, I am doing the 355 build. Thanks for the input. I will let you guys know some specifics later. Glad to know the stock crank will handle whati want.
DirtyDaveW
Mar 15, 2015 07:01 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
thenewkid
Nov 27, 2014 09:41 AM
1LEThumper
Jul 14, 2003 12:45 PM
