Stock LT1 Idle RPM
Old Apr 16, 2005 | 06:42 PM
MRBoss429x's Avatar
Stock LT1 Idle RPM
My LT1 tach used to idel 900ish but after whiteface gauges its 700ish. I heard the stock tach is a couple hundred high anyway so I was wondering if its MORE accurate now. So whats the stock idle? THanks.
Old Apr 17, 2005 | 01:24 AM
Re: Stock LT1 Idle RPM
Is your car an A4 or an M6. The factory programming for idle, engine fully warmed up, is:
M6: 800rpm
A4: 650rpm in neutral, 550rpm in gear.
Remember, the typical stock tach reads 100-200rpm higher than actual rpm, so as noted above, you can only tell the true rpm by looking at the PCM with a scanner.
Old Apr 17, 2005 | 04:21 AM
nin97's Avatar
my tach is 250RPM higher than the scanner
Old Apr 17, 2005 | 09:23 AM
MRBoss429x's Avatar
Alright, I think Ill leave it where it is at 700 warmed up in neutral. Thanks for the info guys!
Old Apr 17, 2005 | 09:28 PM
2000LS1Z28's Avatar
As per a GM OBD1 scanner, my '95 A4 Z28 idles idles at about 675rpms in P when fully-warmed up...And as Injuneer stated, the factory warm idle speed should be 550rpms when in gear...
BTW, like everyone else, my tach seems to read 100-150rpms higher too...
Mike
Old Apr 17, 2005 | 09:54 PM
Tonedef's Avatar
Are the guages just overlays? If they are, when you put them on did you remove the needles?
Gtpguy
Jan 26, 2015 04:50 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
IRABuss
Sep 7, 2011 09:08 PM
