Stock LKT1 rods capability
Old Jun 24, 2007 | 02:06 PM
MichiganSkip's Avatar
How much HP would th stock LT1 rod handle? 500 maybe? How about the stock crank?
Old Jun 24, 2007 | 02:30 PM
MeanGreen97Z's Avatar
Stock bottom ends have been able to push 400rwhp on higher mileage motors. I have never seen an actual GM HP rating but if what you see on here doesn't say 500fwhp then I dunno what else to tell you. I'd say 500 would be a safe number to assume.
Old Jun 24, 2007 | 02:50 PM
rskrause's Avatar
Moderator
Agree with above. They are good quality pieces.
Rich
Old Jun 24, 2007 | 03:33 PM
So, to machine block for 4 bolt mains would just be added insurance?
Thanks guys. That makes the decisions on the engine build a little easier on the wallet. I'm going with TRW/SpeedPro l2256F forged pistons.Any suggestions on Brand of bearings and rings? I've used Clevite bearings before without issues.
Old Jun 24, 2007 | 04:44 PM
mpayne's Avatar
In summit they sold the LT1 powdered metal connecting rods. The description said 500 hp.
Old Jun 24, 2007 | 04:46 PM
mpayne's Avatar
I would just use ARP main studs with the stock two bolt caps. That's what I'm doing and will be aiming for 410 rwhp. What hp are you looking to make? What rpm redline?
Old Jun 24, 2007 | 07:40 PM
marshall93z's Avatar
I've seen them handle 500 rwhp with no adverse effects.
Old Jun 25, 2007 | 01:05 PM
GM rates the LT1 PM rods (only found after mid-94, earlier engines used forged) at 450HP. The two well documented cases of failure that I have seen occured at about 600HP.
Old Jul 2, 2007 | 03:43 AM
SS Joe's Avatar
I had one fail in a low mileage '97 stock LT1 engine (37k); the bearings were perfect, but the rod reverted back to powder at low RPM while driving down the road. My machinist couldn't find anything wrong, and guessed that maybe it was a bad heat treating job.
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
