stock injectors
Old Feb 28, 2006 | 01:16 AM
350pride's Avatar
stock injectors
im putting in a hotcam next weekend and I need to know if i need to replace my stock injectors. My mods are listed below, and yes i will be spraying after the install as well. It is a 100 wet shot. If i need to replace, what size do i need to go with?
pride
Old Feb 28, 2006 | 01:29 AM
FeelTheSpeed's Avatar
Re: stock injectors
I would assume so, just to be safe anyways... I'm gonna be using 30 lb injectors once I decide to put the bottle in
Old Feb 28, 2006 | 07:46 AM
Re: stock injectors
You do not need to upgrade the stock injectors for the LT4 HOT cam. You need to start thinking about new injectors when you approach 400 flywheel HP. You aren't there yet.
If you're running a wet kit, you don't have to do anything to the injectors when you "decide to put the bottle in".... the fuel for a wet nitrous kit doesn't flow through the injectors.
Old Feb 28, 2006 | 07:55 AM
Javier97Z28's Avatar
Moderator
Re: stock injectors
Stock is fine for now.
Old Mar 1, 2006 | 11:39 AM
350pride's Avatar
Re: stock injectors
thanks for the help
Old Mar 1, 2006 | 11:56 AM
Colin91Z's Avatar
Re: stock injectors
I ran a Hotcam with stock injectors for 5 years. You'll be fine
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
spearous
Jan 12, 2015 11:03 AM
