Anyone have a dyno chart of a 224/230 cam?
Old Feb 28, 2006 | 11:13 AM
DuronClocker's Avatar
I've been searching and found a few threads with dyno numbers, but I'm looking for a chart so I can see where the torque is like. Trying to decide between a 2800 and 3200 converter.
Old Feb 28, 2006 | 11:54 AM
shady93z's Avatar
Re: Anyone have a dyno chart of a 224/230 cam?
i do not have mine anymore but i would run the 3200. just my .02. i had the 224/230 cam and i loved it. Ion from madz28 did my dyno-tuning.
Old Feb 28, 2006 | 12:05 PM
CamaroGuy22's Avatar
I am wondering the same thing. I have been told though on 94's there is a stall wall where if you have higher then a 2800 stall and get a great launch the transmission wont shift out of first.
Old Feb 28, 2006 | 02:32 PM
jmzlt1's Avatar
Check out this site www.chris96ws6.com It has good info and he is running a 224/230 cam. You can check my sig for some dyno charts, although my cam is a 218/230 on an m6, it can't be that far off. The torque curve should give you an idea what stall to use. Higher than 3000 stall I've heard you need an ob2 computer to cure the "stall wall". Check with either Ion at madz28 or Bryan at pcm4less. Hope this helps. On a side note, if you didn't buy a cam yet, check out Lloyd Elliots packages. His cams are much better than the off the shelf stuff. Just my .02
Old Feb 28, 2006 | 02:40 PM
I'm actually running a standard gen1 350 small block with MAP TPI computer and LT1 heads/intake in an '88 TA. I "softly" ported the heads and they flow 221/180 at the useable lifts of this cam (non-roller version, only .480 lift). Shouldn't have a problem with any size stall as long as its streetable (either stall will be a Vigilante so it shouldn't be a problem, I have a 2800 in my garage and can get a 3200 for roughly the same price I can sell my 2800 for).
I was planning on going with an LE2 package not too long from now, but I may be selling the car after I finish it and focus on my '98 instead.
Old Feb 28, 2006 | 02:41 PM
Can't get that chrisws6 page to load
Old Feb 28, 2006 | 05:25 PM
Fastbird93's Avatar
I have one, albeit with ported heads:
Old Feb 28, 2006 | 05:50 PM
What power and mods did you have when you did have the cam?
Old Feb 28, 2006 | 06:08 PM
roughneck427's Avatar
Im dynoing my car tonight i have this cam in it i have an M6 but you can see the torque curve this is happening at 7pm pst ill post #'s tonight or tommorow morning
Old Feb 28, 2006 | 06:53 PM
Great, thanks for the graph. I'm going to go pick up the 3200 tonight and get the trans and motor mated again. With any luck/time, the car will be running by the weekend.
Old Feb 28, 2006 | 09:01 PM
1993CaMaRoZ28ofIdAhO's Avatar
M6s are going to put down much better ###s compared to A4s.
Old Feb 28, 2006 | 10:57 PM
Like I said, I wasn't looking for numbers, just an idea of what the torque curve...erm...flat line... started. Looks to be right around 3000 or a little higher, so a 3200 stall should work perfect.
Old Mar 1, 2006 | 12:57 PM
jmzlt1's Avatar
Link works now. Sorry.
HarleyZ28
Oct 5, 2015 06:23 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Russ95Z28
Apr 23, 2015 01:55 PM
racecarz28
Mar 30, 2015 09:55 PM
armedtrigger
Feb 24, 2015 08:30 PM
