Stock bore lt1 head gasket.
Old Jun 4, 2009 | 09:50 PM
GreasyB's Avatar
Ok well I had a felpro 1074 on my old engine and had good luck with it. I would like somthing similar on this engine. It is a stock bore engine just honed to fit the pistons. Do any of you have part numbers and sugestions?
Old Jun 4, 2009 | 09:56 PM
crash4cyl's Avatar
Same gasket should work all the way up to a 4.125 bore....If you only honed it to fit some new slugs you should be fine using the same albeit new gaskets
Old Jun 4, 2009 | 10:13 PM
GreasyB's Avatar
Yea but will the larger bore size of the gasket affect anything? Because arent they meant for .030 over?
Old Jun 4, 2009 | 10:14 PM
RamAir95TA's Avatar
Most gaskets come in 4.125" bore size = even stock. Don't worry about it.
Old Jun 4, 2009 | 10:48 PM
crash4cyl's Avatar
^Exactly, they all usually come about the same bore. You can get them smaller bores but it won't hurt anything being larger. All it does is lower your static comp. ratio ever so slightly (not enough to notice)
Old Jun 5, 2009 | 07:16 AM
bombebomb's Avatar
I had the same question when I was buying parts for my rebuild, 4.125 is "stock" gasket size and that is what you need to buy.
Old Jun 7, 2009 | 04:45 PM
GreasyB's Avatar
Ok so the felpro 1074's should be ok with my set up is what you guys are saying? And I need the 4.125'' bore size correct?
Old Jun 7, 2009 | 04:58 PM
bombebomb's Avatar
I am running 1074's, from what I know all head gaskets for the lt1 are 4.125. It will be fine.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Catmaigne
Dec 25, 2014 12:16 PM
CobraEatr
Jul 29, 2002 11:46 AM
