Stock or AFR Heads
Old Sep 23, 2003 | 03:26 PM
POSSESSEDZ's Avatar
Stock or AFR Heads
Iam deciding on what i should do for the heads, Have the stock ones ported or get the AFR heads, What kind of gains will i get from the AFR'S compaired to the stock ported ones. Iam building a 383 motor with GM847 cam.
Old Sep 23, 2003 | 03:29 PM
Z95m6's Avatar
from what i have heard stock ported are better than stock AFRs.
Old Sep 23, 2003 | 03:38 PM
NiteRider's Avatar
What would be even better is to get those AFR's ported.
Old Sep 23, 2003 | 03:55 PM
Brettinator's Avatar
really it depends on what AFR heads you are considering for your 383? AFR 210's would be MORE than sufficient and there is no way stock setup heads would compare to AFR's heads. Not saying you can't do a lot with stock heads because you can, but bang for your buck and getting it done right, AFR is hard to beat.
Old Sep 23, 2003 | 03:57 PM
FacelessZ's Avatar
AFR heads -> $$$
ported stock heads -> less $$$
Old Sep 23, 2003 | 04:05 PM
BES-383's Avatar
Stay with your stock heads. I had my sock casting heads max ported and the support 557 FWHP.
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
