Will vette servo help 2-3 shift?
Old Sep 22, 2003 | 06:18 PM
Hal Fisher's Avatar
I have a 97 z28 with the 4l60e. I have modified the tranny line pressure with using obd1 pcm and tuner cat but with the supercharger (5#) it hits redline before shifting. Without the supercharger it shifts fine. I know the corvette servo mainly helps the 1-2 but because it is also an accumulator, does it help the 3-4 shifts enough for this purpose (350 rwhp/tq)?
Hal
Old Sep 22, 2003 | 06:32 PM
BlkZ28M6's Avatar
I also would like to know this question. I hit rev limiter to before it shifts also. I have like a 200 rpm jump before it shifts and the trans was just rebuilt. Shifting at 6500 rpm.
Old Sep 22, 2003 | 06:33 PM
WP's Avatar
WP
all f-bodys (Lt-1's at least) have vett servos already in them,and I cant beleive trans shops charge extra to have them installed during a rebuild,to adjust any shift point on an a-4 requires computer programing,
Old Sep 22, 2003 | 07:08 PM
Hal Fisher's Avatar
Thank you WP for that clarification.
Hal
Old Sep 23, 2003 | 04:15 PM
Pro Built Automatics's Avatar
It will help the 2-3 shift because it directs more oil to the 3-4 clutch pack during the 2-3 shift. This is the main reason GM made the Corvette servo according to the story, was to improve the 2-3 shift (it can eliminate the 2-3 flare up).
Jeff1904
Jun 5, 2016 05:00 PM
n2oblkz
Oct 22, 2015 02:31 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
