Still Running Rough
Old Mar 6, 2010 | 02:22 PM
moondance's Avatar
Still Running Rough
After being told the O2 sensors were bad and taking care of oil leaks and such I was hoping the car wouldnt be running rough anymore. Sadly it still is. The guy at the shop said he called it smooth but to me after it heats up it is still running rough. Where the engine isnt idling smooth like at start up. The opti, wires and plugs were all also changed. Is there anything else that could be causing a rough run after the car is heated up? It has no codes but does eat some gas. Thanks for the advice.
Old Mar 6, 2010 | 02:38 PM
Drew24's Avatar
Any exhaust leaks or is the cat clogged
Old Mar 6, 2010 | 03:04 PM
bw_hunter's Avatar
Take a look at the spark plugs. Sometimes bad O2's lead to fouled plugs and the symptoms you describe...
Old Mar 6, 2010 | 03:06 PM
moondance's Avatar
The plugs were replaced with everything else. There are no exhaust leaks and there is no loss in power to lead me to believe the cats are clogged. If I rev the engine when its cold I still notice it popping at the cut out.
Iamherefornow
Jan 26, 2015 04:57 PM
1775.Z28
Jan 11, 2015 10:51 AM
Scottylt1
Jan 8, 2015 02:48 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Scottylt1
Dec 4, 2014 12:31 PM
