Steering wheel radio controls
Old Oct 12, 2003 | 09:38 AM
Raptor1's Avatar
Did a search and nothing came up on this, Can't believe I'm the only one with this problem
On my '94 TA, it's got to the point where the redundant radio controls on the steering wheel don't work any more. Its been a gradual thing along with the radio itself taking a crap. I've sent the radio/CD player off to www.carstereohelp.com for repair.
My questions are, is it the radio causing the problem, or the button's on the steering wheel? If it's the buttons, what do I need to do to fix them?
Any help is appreciated, thank you
Old Oct 12, 2003 | 11:39 AM
cndctrdj's Avatar
ya my left side buttons are dead. and the liht is out on them.
Old Oct 12, 2003 | 01:57 PM
Raptor1's Avatar
Anyone?
Up ^
Old Oct 12, 2003 | 02:30 PM
Seal's Avatar
probably the relay/buttons itself... look on ebay, i saw the whole set for 50 there where at the dealer, its 120 a piece
my lights are out on mine on both sides btw
Old Oct 13, 2003 | 06:51 AM
Raptor1's Avatar
How much of a job is it to change the buttons and/or relays?
Old Oct 13, 2003 | 02:03 PM
Fux0redImages's Avatar
Usually, what goes wrong with those thing is the "plungers" that connect the buttons you push, to the buttons on the circuit board melt or something along those lines. I took mine apart to find, no plungers at all. Someone told me you can use those coffee straws you find at QT or anything along those lines to make new plungers. If you take apart the steering wheel, you'll see what I am talking about. It's not that big of a job. 4 Torx head screws behind steering wheel, undo air bag connections, then unscrew each side of the steering wheel controls. MAKE SURE YOU DISCONNECT THE NEGATIVE TERMINAL BATTERY. You don't want to be hit in the face by an airbag.
Edit.. If anyone knows the measurements on those plungers that I would have to cut the straws, PM me.
Old Oct 13, 2003 | 05:02 PM
Raptor1's Avatar
Thanks for the info, I appreciate it.
Airplanedoc
Feb 1, 2015 07:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
formula79
Aug 6, 2002 11:18 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
