Starting problems
Old Aug 3, 2010 | 05:18 AM
  #16
There are 4 possible causes for the fuel pressure dropping to "0" on shutoff:
-faulty check valve in the fuel pump
-faulty fuel pressure regulator
-leaking fuel injector(s)
-leaking fuel lines between the pump and the regulator, including the connections at the pump/bucket
You have to systematically rule each possibility out. Pull the rails, pressure the system, look for drips from the injectors. Pull the FPR vacuum line, and look for wet fuel. Block off the return line, pressure the system. Look/sniff for leaks.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
