EGR Valve Disconnected but not removed?
Old Aug 3, 2010 | 11:13 AM
speedracer2j's Avatar
On my engine, as in signature, I have my physical EGR valve in place, however vacuum and eletricity have been removed from the valve. Recently I have been picking up on a miss at idle, throwing codes for MAP, and lean right bank o2. Computer throws fuel at it, IAC opens fully, and it runs like crap. My question, without vacuum or electrical is it possible the egr can still open/let air pass through? Could be my vacuum leak issue I am having. I will attach a datalog to look at as well here
http://www.mediafire.com/file/9olvfo...q3/aug2010.uni
Old Aug 3, 2010 | 11:32 AM
wrd1972's Avatar
The EGR can not open up if its vacuum line is removed. However it could slightly open as a result of carbon buildup causing a vacuum leak.
You also need to turn the EGR function off in the tune.
Old Aug 3, 2010 | 11:54 AM
Word. EGR valve has been tuned out... my father installed the engine when I was deployed, and being old school decided even though I have blockoff plates to install it with the EGR valve... Chances are i'm just going to take it off anyway now, eliminate the possibility, I have heard of them sticking open with carbon, I just wasn't sure of the mechanical operation of it... Thanks
dfarr67
Apr 10, 2015 07:44 PM
edman
Mar 13, 2015 09:39 PM
jocamino
Dec 29, 2014 10:15 PM
Cam28_boy
Aug 6, 2002 08:40 AM
