starting problem
Old May 28, 2005 | 09:34 AM
ZSpeed350's Avatar
starting problem
When the car is not warmed up it taked 4-5 seconds for the car to start. It turns and always starts but it has a delay. When the car has been on for a lil its starts up right away. I have a new battery,starter, gas filter, and plugs, what do think the problem may be. I have also cleaned the injectors. Any suggestions-mechanic cant figure it out because when i take it there the car starts up right away because it has been warmed up. Please help-prolonging problem. Thanks guys.
Old May 28, 2005 | 09:42 AM
Ryan94ZA4's Avatar
Re: starting problem
I'd suspect a leaking down regulator or, more than likely, a bad fuel pump. The check valve goes bad in the stockers and causes this. My Z did the same thing; I put a Walbro in and it's all better. Put a gauge on the rail and see what the pressure does. If it drops, check the regulator by pulling the return line and plugging the outlet from the rails. If the pressure stays, the regulator is bad. IF it still drops, the pump needs replaced.
Ryan
Old May 28, 2005 | 10:03 AM
ZSpeed350's Avatar
thanks ryan ill check that
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
