Starting issues with battery relocation???
Old May 28, 2006 | 03:13 PM
  #16
Schurters LT1's Avatar
Re: Starting issues with battery relocation???
Originally Posted by 1racerdude
Use double "0" and it will work every time. Is the size of small welding cable.
So i guess go to a welding shop and ask for double 0 welding cable.....i guess i should start from there.....
Any other ideas ?
Old May 28, 2006 | 03:48 PM
  #17
LJ93Z28GM's Avatar
Go to an electrical supply house a welding shop will rape you on the price.
If it is dropping that much I would have to say you are seeing another problem than just cable size.
The test I stated is to be measured without a battery charger.
Charge the battery till you get a full charge, take it off and now measure at the battery. Now measure at the starter do not go by the gauge on the dash.
See what it drops.
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
David Dorris
Jan 17, 2015 08:10 PM
97z28k&N
Jan 9, 2015 04:58 AM
