Starting for first time after cam install
Old Feb 23, 2004 | 01:28 PM
TUFF LT1's Avatar
Just wanted some advice on things that I should be aware of prior to starting the ole beast back up after the cam install and heads were put back on?? I've already stockpiled enough oil for 4 oil changes and just bought 2 gallons of antifreeze. I'm in the process of tuning for the bigger injectors that I installed. What else do I need to know or expect? Thanks
Old Feb 23, 2004 | 01:31 PM
SVT Killer LV's Avatar
Prime the oil-pump make sure the motor is pre-lubed...
Old Feb 23, 2004 | 01:34 PM
TUFF LT1's Avatar
How exactly do you prime the oil pump?? Not trying to sound stupid but I've never had to do that before. Thanks
Old Feb 23, 2004 | 01:38 PM
96ZRDR's Avatar
Pull out the injector fuses under the hood, there are (2). Also, disconnect the coil wire. Once you do this, crank it a couple of times so you get oil pressure up, this way you will know your pump is primed.
Reconnect everything, and you are good to fire it up.
Old Feb 23, 2004 | 01:42 PM
TUFF LT1's Avatar
That's easy enough! Thanks for the good info. I had no idea that I had to do that. Any other good chunks of info that would save me from possible disaster?
Old Feb 23, 2004 | 02:41 PM
ledfootz28's Avatar
good info on priming the oil pump,never really knew how to do that either.im going to do that once the beast comes out of hibernating also.besides that just make sure all the fluid is up to level
Old Feb 23, 2004 | 02:46 PM
DR.ZED's Avatar
Unplugging your PCM fuse will take care of all of that... spark and fuel.
Old Feb 23, 2004 | 03:02 PM
lt1g3n's Avatar
DAMN good info , thanks guys!!! ive yet to start it ! waiting for headers in the mail ;D
Old Feb 23, 2004 | 07:31 PM
atljar's Avatar
Expect a slightly hard start. Expext smoke from exhaust at first and from underhood where you got oil/grease on the headers.
Eh....thats all i have.
Old Feb 23, 2004 | 07:33 PM
94 CAMRO Z28's Avatar
What he said...
Aaron
Old Feb 23, 2004 | 07:40 PM
neil350's Avatar
Change the oil after the motors ran for about 15 minutes or so.
Old Feb 23, 2004 | 07:44 PM
TUFF LT1's Avatar
I'm glad I posted this question. I probably would have messed myself if when I started the car and it got engulfed in a cloud of smoke and I wasn't expecting it. I told the girlfriend that she can stand fire guard! lol just kidding. Thanks for the replies everone.
Noenav
Mar 1, 2019 07:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
