Starting for first time after cam install
Just wanted some advice on things that I should be aware of prior to starting the ole beast back up after the cam install and heads were put back on?? I've already stockpiled enough oil for 4 oil changes and just bought 2 gallons of antifreeze. I'm in the process of tuning for the bigger injectors that I installed. What else do I need to know or expect? Thanks
Pull out the injector fuses under the hood, there are (2). Also, disconnect the coil wire. Once you do this, crank it a couple of times so you get oil pressure up, this way you will know your pump is primed.
Reconnect everything, and you are good to fire it up.
Originally posted by atljar
Expect a slightly hard start. Expext smoke from exhaust at first and from underhood where you got oil/grease on the headers.
Eh....thats all i have.
Aaron
I'm glad I posted this question. I probably would have messed myself if when I started the car and it got engulfed in a cloud of smoke and I wasn't expecting it.
I told the girlfriend that she can stand fire guard! lol just kidding. Thanks for the replies everone.
F(ast)-body
Feb 26, 2003 09:05 AM
I had no idea that I had to do that. Any other good chunks of info that would save me from possible disaster?
