starter stuck on
starter stuck on
This is the second time its happened to me, i started my car and after it started the starter stayed stuck on for about 30-40 seconds...the first time it happened, it stayed on maybe 10 seconds....has it ever happened to anyone else?....
My starter used to do that (stay on for about 5 or 10 seconds after i start the car). DOes your voltage stay low until it the starter stops hanging? One day i started my car and my starter kept going for about 2 or 3 mins after i turned the car off. It set on fire and started smoking. Luckily i was able to quickly disconnect the battery shortly after. My starter still worked after that, but it turned over very slowly. A reman. starter cost me 160sih dollars plus install time (20 mins).
BTW if you have the intake manifold leak and the starter just keeps going you may run into the problem i had, a small fire! It didnt damage anything really, but made me fix the IM leak pretty quick after that
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 11:56 PM
jackpawt883
Sep 10, 2015 08:53 PM
