Starter stays engaged
Old Aug 21, 2007 | 06:03 PM
Dudeman41's Avatar
I am doing a rebuild on my 94' camaro and I am about ready to start it. I had the coil unplugged and the fuel pump unplugged to prime the engine. I tried starting it twice. It turned over fine after the first time. I waited about 3 minutes and tried again and it turned over but this time the starter is staying engaged. The engine isnt trying to turn over, the starter just keep spinning. Do I have something hooked up wrong?
Also I have put in a mechanical oil pressure gauge and noticed that i was not getting any oil pressure when turning it over. Does it take awhile to get pressure. I only turned the motor over twice.
any help would be appreciated
Old Aug 21, 2007 | 07:18 PM
94zrag's Avatar
To answer your second question, when I primed my motor it took about 10-15 seconds of turning it over before I saw oil pressure. As for the starter, I really don't know, wires touching somewhere
Old Aug 21, 2007 | 07:20 PM
mdacton's Avatar
take the starter off and check it with jumper cables...sounds like its probly bad or you hooked it up wrong
Old Aug 21, 2007 | 08:15 PM
Dudeman41's Avatar
Well I took back the starter and got another one. The first one failed the test at autozone. So i put on the other one and it doesnt stay engaged so I really dont think there is a wiring issue. But now I have another issue. It turns over for a second or 2 and the starter makes a bad grinding sound. Any ideas what that could be?
Old Aug 21, 2007 | 08:21 PM
mdacton's Avatar
what kind of grinding? like something in the starter?
Old Aug 21, 2007 | 09:06 PM
Boosted_Z28's Avatar
Check the teeth on the flexplate to be sure some of them aren't broken or "worn". There should have been a set of instructions included with the starter that explains how to properly measure the distance between the teeth on the flexplate and the shaft of the bendix on the starter. They should also describe how to shim the starter properly to obtain the proper measurement.
Old Aug 21, 2007 | 09:26 PM
Dudeman41's Avatar
Ya I have read a few things on here and I think it needs to be shimmed. The flex plate is fine its brand new. I will get some shims tommorow and see how that does.
Old Aug 22, 2007 | 10:44 PM
Dudeman41's Avatar
Well I think this starter is no good now either. The Bendix turns both ways and they are not supposed to right? Both of these starters were a Duralast reman. from Autozone. I have put in the LT4 hotcam kit and done a rebuild, so this motor has more power now. Do you think its possible that I have broken both these starters, now that my engine is a higher performance engine? I just find it hard to believe that 2 starters that I got were junk to begin with.
Old Aug 23, 2007 | 05:31 AM
jasonisdn's Avatar
take your starter back and buy this one
part # 17124
its for a y-body but fits our cars perfect. shim it a little and you should be good to go. i can't remember the thickness i had to use but it wasen't much
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
