Starter probs w/ trunk mounted battery
Old May 7, 2004 | 01:55 AM
Hawaii93z28's Avatar
I was having a starting problem that kept getting worse until my starter just wouldn't fire when hot. I changed the starter and put a heat blanket on, but nothing worked.
Finally, I had my system tested and it seems I had a lot of resistance between the battery and the starter. Because I had the ground from the battery attached to the rear subframe, it was losing a lot as it traveled through to the front. Using the original ground wire up front to the frame was just not enough. My solution was to run a 2 gauge ground strap (same as the one off the battery kit) from my alternator (or anywhere on the block will do) to the frame. Now the car starts like a champ every time.
Just wanted to pass this along if anyone was having problems. Everyone here has been helpful, I just wanted to return the favor.
Old May 7, 2004 | 02:11 AM
Zepher's Avatar
That is a common problem. People forget that the ground went from the battery to the accessory bracket, or the engine block and don't put a provision for this when re-locating the battery.
Old May 7, 2004 | 09:45 AM
Serene's Avatar
No problems here. I just eliminated that cable since the motor is grounded in many places to the body already. Checked it first with a multimeter then threw that cable out.
Old May 7, 2004 | 10:39 AM
GREGG 97Z's Avatar
Are you guys running power from the battery to the front distr block or straight to the starter? I was running it straight to the starter and it was having problems starting every time. I got so tired of it that I bagged it for now and just moved the battery back up front, I want to try it again in the back later though.
Old May 7, 2004 | 11:13 AM
The previous owner did the relocation, but I'm pretty sure mine is running to the distributor block. It's been that way for about 7 years, with no problems until recently (the ground issue).
HectorM52
Jul 30, 2017 11:46 AM
DSMKilla
Jun 11, 2015 05:02 PM
robcarnut
Mar 20, 2015 03:40 PM
97z28k&N
Jan 9, 2015 04:58 AM
squarehead
Nov 21, 2014 08:02 PM
