starter install with hooker LTs??
Old Jun 6, 2006 | 10:24 AM
JeremyKweens's Avatar
What is all required in installing a starter on my 95 z28 with hooker LTs?? Does the header need to come off??
Old Jun 6, 2006 | 10:31 AM
Javier97Z28's Avatar
Moderator
Re: starter install with hooker LTs??
No, nothing needs to be removed.
Starter replacement should take about 15 minutes. Disconnect battery cable, disconnect two wires on the starter, remove the two starter bolts, replaced & reverse of removal.
Bolts are 9/16.
Power lead is a 1/2" nut
Small purple cable is a 8mm nut.
Old Jun 6, 2006 | 10:34 AM
jsetzer's Avatar
Even with hookers and my canton pan the starter still goes off/on pretty easy. Should drop straight out.
Nov 18, 2023 07:21 PM
maybe2fast
Mar 16, 2015 11:59 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
ModdedNerd
Jan 1, 2015 10:56 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
