Starter indexing
Old Jun 2, 2016 | 07:39 AM
frankrizz's Avatar
Starter indexing
Hey Guys,
On my 94 lt1 if I click the ignition the starter bendix drive
gear engages the flexplate as it should. However I notice that if I just click the ignition on and off without starting, the small gear does not retract. If I move the flexplate manually it retracts. Is this normal? Hard to see if starter gear is engaged when engine is running. Also tried various shims. Same results.
Old Jun 2, 2016 | 09:13 AM
RUDEDOG's Avatar
Re: Starter indexing
After starting flywheel speed overides bendix speed and it retracts.
Old Jun 2, 2016 | 11:05 AM
You do need to check the clearance, but it's hard to do with a stock starter. A bent standard paper clip is close to the required clearance, and might work.
Courtesy of Shoebox
http://shbox.com/1/starter_gear.jpg
Old Jun 2, 2016 | 12:57 PM
frankrizz's Avatar
Courtesy of Shoebox
Thanks, will try that paper clip
Old Jun 2, 2016 | 02:39 PM
And the engine starting does kick the starter gear out of engagement as noted above.
Z28Freak86
Apr 30, 2024 05:37 PM
chevyalltheway
May 24, 2015 04:26 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
mike24
Aug 7, 2002 10:06 PM
Last of a Breed
May 29, 2002 10:31 AM
