starter burned up
Old Aug 30, 2003 | 04:53 AM
simple's Avatar
starter burned up
all she does is click, once, when i try to start it, luckily its a manual and we could push start it
what options do i have other then an OEM replacement, i've heard about the LT4 starter being lighter, with a higher torque rating? is that true?
is there any out there that will work on the LT1 with longtube headers, that are lighter and more powerful?
might as well upgrade if i can....part numbers would be great
thanks
Steve
Old Aug 30, 2003 | 01:21 PM
simple's Avatar
anybody?? its not fun trying to push start the car every time i shut it off need some ideas folks!
thanks
Steve
Old Aug 30, 2003 | 04:27 PM
L44's Avatar
L44
i just had the part # for that because while doing my mcleod clutch install i needed to replace it since the stock shims didnt leave it much room, i kno with the LT4 an the CVR starters they get in the way of the #8 primary on the LT's =/
Old Aug 30, 2003 | 04:32 PM
M93Z's Avatar
Check out part number SUM-820323 @ Summit, it's on sale for $117.35. I just saw it in the catalog today and I'm not sure it will fit but it's probably worth a look.
Old Aug 31, 2003 | 08:02 PM
simple's Avatar
thanks guys, i'm having troubles finding a mini starter that will work!?
who can tell me how many teeth the stock flywheel is on an LT1?
Old Aug 31, 2003 | 08:16 PM
JoeliusZ28's Avatar
my starter just quit to, and the oem replacement cost me about $95. Just out of curiousity, did yours "die slowly?" Cause mine quit all at once without any warning....very luckily, right in the garage.
Old Sep 1, 2003 | 04:01 PM
simple's Avatar
i dont know if it died slowly or not, i was having starting issues for awhile b4 this but i chalked it up to a fuel problem, could've very well been the starter, i guess i'll find out when i get a new one!
how many teeth is the stock flywheel?
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
