rear end drippin
Old Sep 1, 2003 | 03:47 PM
SiDeWaYZz28's Avatar
Unhappy rear end drippin
hey ya . . i noticed my rear end is leaking a little bit and i was wondering what ya think the problem is .. .is my rear end bout to blow???or does it need serviceand a new gasket???i need your help ........
Old Sep 1, 2003 | 03:54 PM
Geezer powered's Avatar
Where is it leaking from front or back.If its the back a nice service and new gasket will do the jog.If its the front its most likely a seal.Both are easy to do
Old Sep 1, 2003 | 04:04 PM
revtime's Avatar
Probably your cover gasket, time to pull it and change that diff fluid as well.
I have a TA girdle and I had a nasty leak, I got a new gasket and some Indian head gasket shellack and the rear has been dry ever since.
Old Sep 1, 2003 | 04:10 PM
x7x7's Avatar
probably the pinion seal. I would take it in to have it replaced. If you overtighten the pinion nut when you replace the seal you'll have toasty pinion bearings in a few months.
Old Sep 1, 2003 | 04:15 PM
doodad's Avatar
Another vote for pinion seal, I am there myself.
Old Sep 1, 2003 | 04:16 PM
thanks for the quick replys
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
