ST chambered muffler -vs- Summit chambered muffler
Old Oct 25, 2004 | 06:08 PM
dmoor88's Avatar
anyone have a side-by-side comparison between a ST chambered mufler and a Summit chambered muffler? im looking mostly for the straight-thru view to see the difference in the inner baffles.
Old Oct 25, 2004 | 10:05 PM
got_hp?'s Avatar
Re: ST chambered muffler -vs- Summit chambered muffler
i had both.
STs are large triangles
summit (actually made by stainlessworks) are much smaller, about half the size. has better welds/quality, also heavier and twice the price.
both sound very similar.
Old Oct 25, 2004 | 10:43 PM
dmoor88's Avatar
yeah i spoke to you when you had the 18" ST's dumped with an X-pipe and you said they were way too loud. Did going with the 30" Summit's help?
Old Oct 25, 2004 | 10:55 PM
lt4 fd's Avatar
well he has a pretty built up motor so its probably louder than a stock LT1 will be... although I have heard the 18's are really loud as well from the guy who sells them... I think I will go for the 24's if I can.
Old Oct 25, 2004 | 10:57 PM
dmoor88's Avatar
ford is running the 3"in/3"out 18" ST mufflers with an H-pipe and dumped with his duals. sounds unbelievable!
Old Oct 28, 2004 | 06:02 PM
lt4 fd's Avatar
BTW which direction do the mufflers face in the exhaust with the open end of the little triangles along the inner wal facing the exhaust upstream or facing downstream?
Old Oct 28, 2004 | 07:04 PM
dmoor88's Avatar
id imagine the openings of the baffles should face 'upstream,' or towards the engine.
G-BODYT56
Jan 14, 2022 11:14 PM
colts0455
Sep 22, 2015 02:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
