SS Airbox install problems...
Old Jan 27, 2004 | 04:18 PM
LanceJoker's Avatar
Hey guys,I just bought a SS intake to match my Suncoast SS Hood.Problem is when I went to install,it makes contact with the driver side AIR connection.Anybody else have this problem,or know how I can get this airbox on correctly.
Old Jan 27, 2004 | 05:10 PM
LanceJoker's Avatar
Anybody ??
Old Jan 27, 2004 | 06:30 PM
Spinner's Avatar
Been there, done that. Suncoast hood AND airbox. Same problem. I just took a BFH and beat the metal part of the AIR hose out of the way. Worked fine until I removed the AIR altogether.
Old Jan 27, 2004 | 08:04 PM
LanceJoker's Avatar
Thanks,I may have to bring out the hammer.LOL.Thanks again.
Old Jan 27, 2004 | 08:18 PM
Spinner's Avatar
No problem, ALSO -- The fuel lines go over the airbox. However, they come in a big ribbed plastic tube. I cut out ~4" of that tube where the fuel lines passed over the airbox. If you dont, that big tube will hit when you try to shut your hood, so if you haven't done it yet, be sure to do that.
Old Jan 27, 2004 | 08:19 PM
Spinner's Avatar
Here's a pic of the fuel lines. I've since straightened the filter out. (It's not crooked anymore )
http://images.cardomain.com/member_i...27_34_full.jpg
Old Jan 27, 2004 | 09:31 PM
LanceJoker's Avatar
Any chance you have a pic of the air connection before you remvoed the system?Also,does your car pass emissions with no AIR hookups?Just curious.Thanks.
Old Jan 27, 2004 | 09:38 PM
Spinner's Avatar
No pic, I just beat it sideways and down towards the brake lines until it cleared. You don't need AIR to pass emissions. Matter of fact, AIR does nothing for the sniffer test at all. IT only runs for 2-3 minutes on cold startup.
Old Jan 27, 2004 | 09:56 PM
LanceJoker's Avatar
Hmm....I did not know that.Maybe a new weekend projec tis in the making.Thanks for all your help man.
Old Jan 27, 2004 | 09:58 PM
Spinner's Avatar
No problem
Old Jan 28, 2004 | 09:16 AM
LanceJoker's Avatar
Hey man,Just wanted to let you know that I did what you said hammer and all.Now it is on the car and functional.Woohoo.Thanks so much man.
Old Jan 28, 2004 | 09:49 PM
Spinner's Avatar
No prob. BFH =
Old Jan 28, 2004 | 09:57 PM
TraceZ's Avatar
Spinner is correct about the limited function of the air system, but forgets that in some states you will fail the visual inspection if you remove it. Check your states policy.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
formula218
Dec 2, 2014 04:27 PM
