Squealing sound from inside the motor.
Old Feb 14, 2008 | 06:04 PM
henryz28's Avatar
Hi guys I got a squealing sound from inside my motor in the front. My oil pressure is good so I don't think its a bearing. But when I did my Colyes dubble chain their was a plate that went on after the chain on the crank, befor I put on the cover. I think this plate is being eaten up by my chain. Was I supposed to leave this out when I installed the dubble chain? The plate is between the cover and the chain my uncle said it was to oil the chain so I left it on,but I think it is rubbing on the chain. thanks
Old Feb 14, 2008 | 07:51 PM
OBE1 95Z28's Avatar
Rule out the easy stuff first; remove the accessory belt and fire it up to make sure it's not external stuff (if you haven't already).
Old Feb 14, 2008 | 09:29 PM
henryz28's Avatar
Ok I just pulled the belt. And it is as quiet as can be. The dam alternater I just got is making the noise. The reason I brought up that plate is because befor the chain did eat it up. But I clearenced it and it shouldent be hitting now. Glad it was not internal that would have been hell. Have any of you guys had this problem with autozone alternators? I bought the lifetime one so I shouldent have a problem returning it sence its only been 1 month. That chain is as strong as hell it ate that plate befor and did not leave a mark on the chain. Thanks for the tip on removing the belt.
Old Feb 15, 2008 | 06:32 AM
jhthornley's Avatar
yes
I went thru 2 alternators before I got a quiet one.
replaced the "tensioner pulley" too, which quieted it down more.
Javi Fierros
Jun 1, 2015 11:41 AM
Javi Fierros
Jun 1, 2015 12:54 AM
warmeck
Mar 22, 2015 06:43 PM
squarehead
Nov 21, 2014 08:02 PM
