squealing belt or pulley?
Old Aug 26, 2010 | 12:28 PM
  #16
RamAir95TA's Avatar
Squealing at high RPMs could easily be belt slippage. Pretty common.
Old Aug 26, 2010 | 12:34 PM
  #17
GRIDERMAN87's Avatar
you could try spraying the belt down with water, see if that makes it worse....if it does thats probably the problem
Old Aug 27, 2010 | 12:51 PM
  #18
bigbluegmen2008's Avatar
Thanx to everyone that helped out, took my baby to Chevy and come to find out the previous owner put the cheapest belt on the market on the car. I personally don't like to hear the belt squealing over the nice sounding motor and exhaust so word to the wise don't be cheap with your lt1/ ls1 camaro. The car sounds great now.
Old Sep 6, 2010 | 01:07 AM
  #19
belt
My new belt is squealing, what is causing the slipping?
Old Sep 6, 2010 | 08:47 AM
  #20
Is it the correct length? Is the tensioner pulley in the correct operating range? If you look carefully at the tensioner pulley base (the part that contains the springs that provides the tension), there is a pointer and the acceptable position range for the pointer is marked. If the pointer isn't within the correct operating range, the belt isn't the right length.
A lot of people get good results with the Goodyear Gatorback belt.
Old Dec 2, 2010 | 06:02 PM
  #21
jeffrox13's Avatar
Exclamation Re: squealing belt or pulley?
Mine is doing the same thing. It squeals on and off. But it will do it alot when i accelerate. I thought it was the belt so i replaced the belt and it still does it -_- i have videos of me running it with and without the belt. Please help. 95 Camaro 3.4L manual.
here is the video http://www.youtube.com/watch?v=g0NSbPp8ovI
Old Dec 3, 2010 | 09:27 AM
  #22
97Z28Muscle's Avatar
Sounds like a belt or tensioner to me.
Old Dec 3, 2010 | 01:10 PM
  #23
ACE1252's Avatar
Originally Posted by bw_hunter
I couldn't open the vid....is it an LT1? If it is, the waterpump is not driven by the belt. it get's it's drive from the cam.
It's a 3.4 V6.
I can hear a small intermittant squeal with the belt off, but I have no idea what it could be....he is going to have to isolate the sound with the mechanic's stethoscope.
Old Dec 3, 2010 | 10:16 PM
  #24
Fred-this is LT1 engine tech only, right?. Maybe this should be moved to a V6 section for better responses.
Old Dec 4, 2010 | 06:28 AM
  #25
Originally Posted by ACE1252
It's a 3.4 V6.
I can hear a small intermittant squeal with the belt off, but I have no idea what it could be....he is gong to have to isolate the sound with the mechanic's stethoscope.
jeffrox13
You made a couple of mistakes when you posted this. First, this forum is only for the LT1 V8 engine. Second, you highjacked someone elses thread, throwing it into confusion.
I'm going to suggest that you post this on the correct forum. All other posts relative to your misplaced post will be deleted.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 7, 2015 07:19 PM
