sputtering problem.
Old Apr 26, 2009 | 09:05 PM
Nick-camaroSS's Avatar
sputtering problem.
i got a 96' camaro z28 SS. its having some problems when it rains out.. it likes to sputter when i accelerate. any idea what it could be?
Old Apr 26, 2009 | 10:39 PM
Sound like something is sensitive to moisture. Possible candidates are the distributor (Optispark), coil and plug and coil wires.
Old Apr 26, 2009 | 10:49 PM
93FIRETURD's Avatar
i second that, a good way to elimenate the wires is to get a spray bottle of water spray the wires down. Then put the car in drive and, while holding the brakes, give it some gas. If the sputtering occurs the wires are the culprit i believe this method should work with the other possible culprits, however, that i cannot guarantee. Good luck.
Old Apr 28, 2009 | 02:37 PM
alright ill try that out. thanks alot!
Old Apr 28, 2009 | 02:41 PM
derrickgott007's Avatar
Unplug your MAF sensor and try that....Mine did the same thing. But I don't know if a 96 has MAF.
Old Apr 28, 2009 | 07:00 PM
All 94-97 LT1's have an MAF sensor. 96 is vritually identical to your 97.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
