Spun bearing...
Old May 25, 2004 | 12:15 AM
Heatmaker's Avatar
Advanced Member
Spun bearing...
How do you avoid this?
Old May 25, 2004 | 12:28 AM
ibanez6rg's Avatar
Well, you can't just absolutely avoid it. It happens if it happens.
Good oil pressure, don't over-spin the bottom end, and make sure you have oil.
Old May 25, 2004 | 01:24 AM
cmillard's Avatar
Make sure you have plenty of oil (not too much, some like to run 1/4 at low, I run level.) Check you oil pressure, you'll want 10 psi per every 1000 rpm. If you're at 6000 rpm and don't see 60 Psi, don't try going to 6500.
I spun my stock bottom at 6400+ back in 2001, I wont be doing that again.
-Christian
Devinfoote87
Feb 12, 2016 03:21 PM
jackpawt883
Sep 10, 2015 08:53 PM
12SCNDZ
Feb 18, 2003 11:08 PM
12secondv6
V6 Tech
Dec 19, 2002 12:15 PM
95LT1Z28
Advanced Tech
Jul 16, 2002 11:41 PM
