Springs for the GM 847 cam?
Old Feb 20, 2008 | 11:36 AM
Rising Phoenix's Avatar
What springs would be ideal for the GM 847 cam? Here are the specs on that cam:
Duration @ .050 = 232/242*
Lift with 1.5's = .539/.558"
Lift with 1.6's = .575/.595"
LSA = 112*
The Comp Cams website says to go with the 26986-16 springs on their two bigger "XFI" cams (the 847 appears to fall in between those two), not sure if those would be ideal for the 847 though. From what I can gather, the 26986 are the Beehive version of the 986 dual springs.
Also, if this matters, I am running the Crane gold self aligning 1.6 rockers. (these: http://www.jegs.com/i/Crane/270/10758-16/10002/-1/744608|10231 )
edit: I also want to find out if the recommended springs will fit on the stock LT1 heads without any extra machining.
edit2: Looks like I'll be switching to NSA rockers + guideplates and selling off the SA ones I have now
Old Feb 20, 2008 | 05:02 PM
MichiganSkip's Avatar
LSA = 112*
I believe that's a Crane cam. I'd do a search, get the Crane P/N and then call Crane and ask them .
Old Feb 20, 2008 | 05:04 PM
http://cz28.com/forums/showthread.ph...ht=847%2Bcrane
post #3
http://www.cranecams.com/index.php?s...41&lvl=2&prt=5
Old Feb 20, 2008 | 06:09 PM
marshall93z's Avatar
234/242
Old Feb 21, 2008 | 08:28 AM
*bump*
Thanks for the info, still hoping for someone who actually has the cam to give me their input.
Old Feb 21, 2008 | 11:58 AM
Vicious95Z28's Avatar
Well, to be honest most guys aren't going to post on this thread because topics like this have been beat to death.
You don't have to hear from some1 that has that cam to get valuble info. The PAC 1218 springs w/Comp 795 retainers, the factory locators and some +.050 614 Comp locks will put you in the happy spot.
Old Feb 21, 2008 | 12:05 PM
Thanks. I tried searching but I wanted the most current info possible. The +.050" locks was an important piece of information that a lot of my searching didn't turn up.
Old Feb 21, 2008 | 12:11 PM
No problem
Old Feb 21, 2008 | 12:56 PM
That's exactly what I have, just haven't fired it up yet.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
grabbem88
Feb 22, 2015 11:16 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
