Spring Installed Height
Old Feb 25, 2005 | 03:25 PM
"White Knight"'s Avatar
How close does Spring Installed Height have to be to spec? I just don't want to go buy a micrometer for it--even though i will probably end up buying one. I am thinking of measuring a peice of something with a caliper that measure to .001 slide that in and shim till i get it to that height--what do you think?
The valve tips are going to be worn down...so how much shimming am i looking at?
Old Feb 25, 2005 | 03:28 PM
Re: Spring Installed Height
I guess summit sells one for like $40 so maybe i'll just get me one
http://store.summitracing.com/defaul...=egnsearch.asp
This Com Cams one looks nice too--has bigger range too
Old Feb 26, 2005 | 06:25 PM
arnie's Avatar
Take the springs to a place that can check the spring pressure. The installed hgt., is just one facet of spring install.
Old Feb 26, 2005 | 08:24 PM
LT1 Bunny's Avatar
what kind of springs you running? are heads on or off the car??
usually whqat you do is get it as close to the middle as i can....what i mean by this is that if the say that you need to install springs in the range of 1.750 to 1.550 then ill do 1.650 .
help any???
Old Feb 27, 2005 | 02:25 PM
SStrokerAce's Avatar
I've done it a bunch of wasy but I like the Comp Spring Mic.
When I setup a head I like to get them within .000 to +.010 of the installed hieght I'm shooting for.
Bret
Old Feb 28, 2005 | 10:07 PM
I'm just using LT4 springs. Heads on the car.
How much will they charge though......it's so easy to do---if it's going to be 100 bucks than i rather just buy a spring pressure checker for 75bucks--everything costs soo much just to have them push the spring down--since I will be using it later i'm sure I midas well just go buy me one. Anything is better than my 130,000 mile springs......It doesn't have to be that close--since it's the stock cam...not like i'm needing the extra pressure really anyway.
Where would i get shims to change height if it's off?
Old Mar 1, 2005 | 05:00 PM
arnie's Avatar
Originally Posted by White Knight
How much will they charge though......Where would i get shims to change height if it's off?
Not gonna quote a price here, as someone will make a liar out of me. We're talking nickels and dimes here (comparitively speaking) to have it done. Shcek speed shops, parts houses, or cam mfrs. sell them. Important to get correct ID/OD shim obviously.
Carogna'sZ-28
Feb 3, 2015 07:04 PM
cmdeshon
Dec 12, 2014 10:51 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
MislMan
Jul 19, 2002 11:41 AM
